mfain
After reading Grumpy's article, I looked and could not find a place to put a 20"X50" radiator to have 2 square inches per cubic inch for cooling. LOL
I didn't get how to read that because wouldn't multi-core radiators reduce that size requirement?After reading Grumpy's article, I looked and could not find a place to put a 20"X50" radiator to have 2 square inches per cubic inch for cooling. LOL
what's fun is it kind of fixes that front tire gap... because I can move in the same direction the flare is already going - makes it a lot easier to finish.they match up nicely on the back, and bigger fender flares always look cool!!!!!!!
I was going to move it inside last night but ran out of time...I am jonesing for the buick sedanette.....
Here is what I did. The first photo shows a circle where DSE (GearFX) had me drill an tap for the lower drain line. It is on the bottom of the case just behind the pinion bearing. The pump is a Setrab gear driven pump. There is a Setrab filter in front of it. All lines are -8. The cooler is a Derale with integral fans. Air is ducted to the cooler from scoops just in front of the rear tires. Hope this helps.Sooooo, one of those 'fixits' from Optima was the clutch seemed to be starting to slip - so part of the fix is going to be changing rear gears to 3.73 from the 3.45 that it is now. While I'm at it, it's time to put the cooler on it, but never ever done one. what do I need to know about rear diff cooling?
