SuperBuickGuy
so to toss a couple of thoughts out there - probably dumb, but I need to ask so I know - what is the optimal temperature of the rear differential? if I run lines to the front (ala what GM did with the Camaro), should I also cool the transmission as well?
a bit of a difference between those and mine. Mine has a cooler inside the differential cover so it's a water system it doesn't move oil but rather heat exchanges. Now to ask again, if I tap in and out of the TKX transmission, can I use ATF as my heat transfer medium? figure I'd daisy chain - other thought is use the cooler in the radiator so that it would maintain a minimum temp as well....
I am going to cool the PS as well and that brings problem number whatever, where to put it.
