Very nice.
I've thought about those, the problem is they're in the way when they're not in use plus you need a 4' aisle to roll it along (not the pictured, the ones like Home Depot example).
this is what I use for a 10' reach height, mine is called a 6' height with a 4' high platform.
I like the idea, I really do however there is one, slight problem with it.... it is far easier to move a lever to make heavy items defy gravity then it is to hoof them up stairs. I'm old enough that I can get away with that excuse.....i went for the collapsible poduium ladder for that reason, it has the platform at 4' you stand on it and it has a "guard" rail you can lean against, it gives a 10' height but you still have to get the boxes down from there. it works great but if it was taller for the plat form it may make getting boxes down harder. i can easily get a box and hand it some one at this height or get it down my self it it was taller it might be more difficult/dangerous
i like it, hard to argue with one of those platform lifts that you can drive, Holiday lights would be fun with thoseI like the idea, I really do however there is one, slight problem with it.... it is far easier to move a lever to make heavy items defy gravity then it is to hoof them up stairs. I'm old enough that I can get away with that excuse.....
No real room to move the wheel in or out and still run the 13X18 wheel with a 358mm slick. The 5.75" backspace is the maximum to accommodate the Decalink suspension, and Apex and Forgeline can only get to about 7.25" on a 13" wheel with their one piece forgings. Finspeed built me a set using Corvette GT Prototype forgings (they only had 3 - used 2 for my rear wheels), but a CNC data entry error resulted in the wrong backspacing -so unusable. They haven't been able to find another GTP forging. I do have two sets of Forgeline GA3Rs (three piece road race wheels with titanium fasteners), but I was trying to find monoblock forged wheels to save a little weight.Pappy -
The rear end would be a bit less sensitive to "scrub" than the front. So, what if the wheel was moved in/out with some small spacers - or LCA/UCA/CV adjustment? Or, maybe the wheel/Tire combo would be a rubbing issue?
I gotta' say I'm typing "Out loud Here," guess I need to a thought experiment to slow down -- its raining, I'm back home from the boat (it is sold) and I've and lots of work to do here on Elvira - so guess I'm avoiding getting to it.
Aaron - Those are NICE wheels - Maybe I should have stayed 18 inch - not been "wedded" to 15s. DOOOH!
4100 cfm is a lot. What interests me is that blade design and that it doesn't appear to create as much drag as typical fans.It is early (and, pre-breakfast) but the price really got me thinking (and looking). I had a bookmark that took a few minutes to relocate, but I'll be heading off on the radiator/fan plan too. SO, long time back - pulled this one to review:
thoughts on cooling
read this, yes theres a good deal of info in the links worth the time and effort, and yes its well worth your time to read thru keep in mind, that if your engine is mechanically functioning correctly, IE there are no problems like leaking head gaskets or the wrong head gasket or a cracked head...garage.grumpysperformance.comGrumpy has a lot of good info and I'd bet you've already looked it over, but still a good "share" for the rest of the gang.
I note at $400+ it doesn't include the digital controller - huh? Soft start is a good feature, however. But, you'll want a shroud - purpose designed for the new radiator and ductwork, but this or similar could be incorporated.
it would be kind of cool if it sounded like a turbine spooling up....You'll get performance that you can measure with the bars!
