Plastic Fantastic 2
as with most, cheap headers, these sort of fit
some trimming required
yum, tasty fiberglass
oddly, it's not at the same level (horizontal)
more hacking
and this side (passenger) looks to need nothing
first step, put spacers in the motor mount
better but where those lines are need heat
now it fits
however, all is not peachy
I had this same issue on Plastic 1
driveshaft mostly installed (need 2 more clamps)
someone asked me once how far the side pipes hang down.... not at all
and Photobucket - I'm moving host, but that means that some of my old threads are going to be de-pictured... sorry, but at this point it's kind of the only choice (and I'm not backing off fighting them)
more bits waiting
this is cool
I think hookers fit better than those. I did buy a special spark plug socket with integral u-joint and cut it down some, but otherwise no issues.
Looks good, great progress.
Thanks for the clone greenwood chassis link. Rpmdyno.com, anyone seen more of his build?
I had hookers on my prior C3 but it was a SBC. This wasn't terrible, it just took fiddling. That said, I think I'll really appreciate the stainless steel tubes rather then the steel of the Hookers.
what hosting are you going to? I may follow.
that engine install really looks great. it certainly does take up all the space there is to offer....
the Corvette engine compartment is spacious considering I used to my make my spending money building V8 S-10 trucks and Blazers.... there, 1/4" would make or break a fitment
Starter, wired
distributor with adjustable collar, arrived
Spark plugs, gapped and installed. In case your curious what lights off the beast - Briggs and Stratton spark plugs.
Dog installed
linkage, installed - one of those times I'm really glad to have a shop full of parts, my goodness that was a pain finding all the bits that worked together
I think the oil cooler is going in front (just not that oil cooler)
Spiderman had red webbing today
still need to do a fuel system but at this point the drivetrain is together (brakes, clutch, driveshaft, etc)
Time to build a carb
all cleaned and on the new base
I modified the base for boost-reference, so I had to 'fix' that
I know the PO reads this, so normally I don't point stuff like this out - but really, stop it.
should look like this
my favorite, bare wire to nowhere.. think it's a horn wire..
tempted to one-wire this
'the right hose' yeah, no... oh well, I was looking forward to building another upper hose out of stainless
this is probably too close to rice, but I like these gauges because they're easy to read
Carb assembly
and a problem - the base uses a lever that turns on the body of the carb... which isn't on the proform body
so now I wait for another base...
but it still works for what I need right now - wire routing and fuel system building
the pump
first step is to pull the tank apart so I can install - 8 feed lines and cap the other lines that I won't be using.
pump will go here...
oil sender installed
and wiring commences
Progress - I cut up several trees that fell in the last windstorm and got prepared for the one that's coming tonight... that said, I did get a bit done
a quick how to make wires
bend tabs more
crimp
halfway there
all the way there
Nice! I'll have to snag one of those tools when I get to that point. I like nice and tidy plug wires. Replacements, even those that are supposed direct fit, never fit the way I like.
it comes free with the MSD 8.5mm cut-to-fit set.... what was funny is they didn't advertise that at all, but I'd been having such trouble with wires that I figured I'd buy a decent set of wires - the tool, by itself, really makes the wires a great deal.
That's a nice bonus then. It's amazing how having the right tool makes the job so much easier. For MSD to throw it in is cheap insurance for them to to make sure their product gets a quality installation. Good on them for making sure we get it right. I like filling my box with tools anyway. ;-)
Onto the fuel tank
then I realized that one of the fittings wasn't AN
a bit of welding, a touch of paint and it'll be ready to go
more work.... first, finish the carb
for whatever reason, the clutch rod was too short.... I can fix this
cleaned up the brake dust from the wheels
then put more dust on them
I'm not going to over think this.... it's flares, it's a race car....edited
for the record, these are 3/4 inlets.... not 5/8....edited
that's done, onto the fans.... these fans came of the Wanderer, they're from a 2000 Impala and fits pretty darn good
fitting
on the radiator
and as I suspected, it does not fit as a unit without some work
however, with a genuine Corvette motorcycle strap, and removal of a few bolts...
a bit of cutting to clear the upper a-arm
and I now I have dual fans with a pre-made shroud
I feel like breaking out into song.... "I got parts, they're multiplying"
then...
dagnabit... I ordered - 8 PTFE line, the box says - 8 PTFE line... that ain't - 8.... - 4.... screeech! to a stop
you know, it'd have been nice had they included the 90* fitting for the - 8 line rather then a - 6 90* fitting... oh good grief
at least the new carb fuel line looks pretty
and there's a good spot for the regulator
thinking the pump isn't going to work there.... nuts again
then I had to deal with that f***ing Jeep ..... every time I work on it, I find yet another screw up... this time, the dealership monkeys couldn't figure out how to put a light bulb back in
at least they're consistent?
the rest of that story is that whole last thing with the lug nuts ruined a rim.... but it's mostly because the pad issue (that was caused because I couldn't get the wheel off).... oh well, I'll continue my marketing campaign for them....edited
Upper radiator hose installed (and lower, not shown)
PTFE fuel line - still waiting on parts from Summit, more then a little annoyed about their lackluster response
take 1 on the radiator support
now in steel
bit of shear work and press brake action and we have something that looks reasonable
next up weld it then paint it so it's pretty
as an aside, I can't believe how well that 2000 Impala fan set works for this application
