stinger12
- Joined
- Mar 28, 2008
- Messages
- 832
Thanks for the info. I too have done a ton of research on epoxy resin and fiberglass matt...and epoxy resin over polyester resins and vise versa. I called west systems about a year ago and talked to a very knowledgeble expert. They did a lot of testing on the matting and epoxy over the cured polyester resin (and vise versa)...and so I am listening to what he told me to do. I don't have issues with epoxy wetting out the matt - it just takes longer to wet out than it does with regular polyester resin. I use a regular matt with styrene still in it - he told me the testing they did showed no difference other than the wetting out time. Another thing to consider is this - regular body filler is essentially polyester resin, with fillers. Nothing special. Yet you can still put that over top of epoxy fiberglass repairs without any issues.
To each his own...I'm not gonna get in a pissing battle over this - although I do appreciate the info you provided to me, so please don't take it the wrong way.
Since I don't have very much weight in the car, the rear spring is barely under tension. I called Mike and he talked me through a bunch of it...and why my frame wasn't level like it was 4 months ago. The jist of it was that the rear spring is flimsy when there is no real weight in the car...so things can change easily when the car gets moved in and out of the garage.
He walked me through relevelling the frame to where it used to be, so problem solved. Just a note for you guys who haven't done this before.
Anyways, here is where I stand right now...
I still have a lot of lip-building to do. Once done, I will carefully trim it all the way around the flare so it is nice and round. Here are some more fiberglass pics.
Another thing I want to point out is how much material I had to add to the bottom of the flare. It was essentially flat, and that's not how I wanted the bottom of the flare to look. I wanted the flare to really stand out from the quarter.
I built the bottom of the flare way out, and when the lip is finally round and finished, I will go on the inside of the flare and grind that massive 1.5" thick fiberglass down to 1/2", just like I did on the front flares.
I also started fiberglassing the doors.
This was a VERY productive weekend. I got a lot of stuff done:cheers:
