SBG's C3
you musta got the high performance reverse flows. These are what ya call restrictive - maybe turn 5K thru these.
Grampy
wow, now I have to figure out another way of advertising them as mine are a lot bigger than that.... you have no idea how tempted I was to simply blast a through-hole in the reversion mufflers rather than buying new - now I'm glad I didn't
and MidAmerica and/or Ecklers is getting richer
So I checked the runout on the rear bearings.... which was a waste of time
what this picture doesn't show you is that I took the nut off without needing to loosen it - what you can see in the picture is my next Corvette purchase..... who knew that blanching could make curves
until I bought this car, it was stone stock - and I suspect this happened before I bought it
also notice the nice rust color.... strangely the bearings were neither noisy nor crunchy
while the passenger side spindle dropped out (literally), the driver's side took a bit more convincing (20lbs of convincing)
picture of how the brake shoes go together.... thinking I might need to replace these
I though all c3's had 4 wheel disc brakes. Never knew some had drum brakes.
Remind me again... why do I need a parking brake? it is the biggest PITA to clean, put together, adjust, and make the console fit around.... oh yeah, because I like doing e-brake turns :D
However, because of this, this job is taking me forever... but I don't have all the parts (missing shims), so it won't be together until next week at the earliest
got some parts
I haven't decided whether or not those spindles are Chinese (they're Yukon) but it'd sure be cool if they were.... :chinese:
and pressed in studs.. sorry to disappoint TT, they're ARP and come from the People's republic of California....
this is the bad side - maybe it can be seen - the race has waves in it (friendly little chap, ain't it?)
this picture is to remind me what side the "wide" race came out of
all the other parts cleaned and POR15'd
press races in place
schnazzy tool (not from Napa)
works like this
used for checking play (should be between .010 and .025)
shims are in the inside but this shows assembly
starting the assembly of trailing arm
I'd post this on CF, but I'm sure I'd get grief for using mexican races with japanese bearings.... oh, and I'm .002 off on the tolerance (too wide).... ask me if I give a schmit :D
more progress
For those who wish to rebuild brakes - here's how the brakes go together
one of the problems I had was a frozen adjuster... best I could find locally was one from a Camaro - so a bit of modification was in order
there, fixed
this is the completed parking brake assembly
my press paid for itself tonight
hey, getting back together
and the other side
I've got a ways to go yet, I need to change the geometry of the lower control arms, and put the rest back together... then get it aligned (not enough alignment shims either - but I made due)
anyway, despite the grief I've been getting, I did manage to get it pretty close to done (literally, one bolt away - one bolt that I have to purchase)
true ARP bolts for lug bolts
I'll be so not stylish - but I so don't care, I've never seen a person stylishly slide into a wall after losing their tire... but then again, I hang out at the wrong places (churches, courts, etc)
and it looks pretty much exactly like it looked before
guess I overlooked this for a while, nice progress !!!
were you able to get he endplay correct with he shims that came in the kit? I had my shims custom ground (thanks Gary) to get he clearnace perfect to under .002" .... think I ended up at .0015" dry without grease.....
I ended at .0011, and .0023 without having to shave shims
also, I realized after I put it together, I could have simply put the large shim (the bell shaped one) in my lathe and taken .0005 off
and I'll say this forever, the smartest thing I unknowingly did was buy the set up tool... that makes life SOOOOOOOOOOOO much easier
the one place I didn't have enough shims was for the johnny joints in the trailing arms - I ended up using one of my thick shims (that didn't get destroyed being removed) to make up the difference....
Alignment
replacing bumpstops
now to finish the interior and get the last little bits on the outside (aluminum strips)
I can safely say I won't need a radio as I already have stereo :thumbs:.... it is a bit loud for the geriatric and tree hugging types :grin:
time for a review of the updates to my car.
First, a recap
tubular control arms
remove power steering
adjust steering box
bilstein shocks
poly joints
van steel arms
adjustable control rods
johnny joints
420# spring
stock springs front, minus 1.5 coils
1 1/8" sway bar
no rear sway bar
:bounce::bounce::thumbs::thankyou::clap:
granted, it's wet out... so I had to be kind of careful - but dang this thing drives and handles excellent!
well, continued with the finish-it-up list
to remind, here is the rear end before, note the driveshafts go down to the wheels?
now - much better
the theory being, with the driveshafts as the upper control arm, you want them to pull in and the bottom to push out (more camber) in a corner.... now it'll finally do so correctly.... sad thing, I've no idea how I managed to get it lower - car sits at the same ride height
and the interior... new steering wheel, and now full dash lights (special, huh?)
I just need to find a new brake console (will check with friend tomorrow).... finally down to the last little bit list :thumbs:
Longer outboard bolts on the rear monospring. They will remove the tension on the spring and lower the ride height and road clearance.
