TT, please note that you may need to massage the trailing arm a bit in the spot where the bearing housings arm goes under it. Mine didn't quit seat completely, so I will have to grind some off.
Furthermore, the brakebracket makes the bolts get so close to the assembly that it gets difficult to turn the bolt. Some grinding there also.
I know it has been posted here. But can someone give me a name as to who can manufacture the splined two piece half shafts in the states?
Thanks,
Ralphy
Had mine done by
TATTON'S DRIVESHAFT'S
curtis. 1-801-685-0056
425.00 for 2 driveshafts. both with the 1350 slip and spline
and a 1350 weld yoke on the other end ,with the 2 1/4" 250
wall tubing and the solid spicer ujoints. shipped to you.
http://stores.ebay.com/TATTONS-DRIVESHAFTS?_trksid=p4340.l2563
the second is that i failed to improve the front suspension bushing setup so that they match the rear which is almost completly solid with this setup.
Had mine done by
are these the shafts for $425 ??? 1350 is the stock U-joint size ???
Yes........ MYBAD79 those are the ones that Tatton's made for me.
If you interested.......... Ill look for my invoice number, so they can look it up and match . :thumbs:
I was wondering about this, how about installing these instead of solid rod ends
http://www.speedwaymotors.com/Mr-Roadster-4-Bar-Rod-Ends,25122.html?parentDisplayId=1583
Still make the bars adjustable ..
Would this make it a bit less racey and a bit more street?
Thanks,
Ralphy
Had mine done by
