BRUTAL64
Neanderthal
Not without a bunch of shims or slotting the cross-shaft.
The popular idea is that you can slot the cross-shaft 1/4 inch and get the additional 2.5 degrees. This is wrong. The cross shaft is about 10 inches from the lower arm pivot, an additional 2.5 degrees is almost double that. If you were to slot the arm 1/2 inch, you would seriously weaken the cross-shaft. There isn't much metal there:twitch:
Actually, Gulstrand has a templete for moving the upper control arm crossshaft bolts forward and down. Better than slotting the crossshaft.![]()
I think you want to move them down and to the back. Not sure how easy this is to do with the engine in place however. Might be easier to make cross shafts like Bird suggested.
Maybe, down and back. I looked at this templete many many years ago.
