69427
Are you running roller rockers on the new motor?
No. I've just got the stamped steel rockers (Comp cams brand IIRC) with the bushed tip rollers. Nothing fancy, but they fit under the stock covers.
The copper cable I used (similar size to stock) weighs .35lbs/ft
Another thing to look at would be what your current needs are... you may not need the same current capabilities as stock with a modern more efficient starter. Ignition retard during cranking may help drop this number too
what about a 8lb hood?
About the doors, I thought about "holing" the steel bottom of them, hard to see if you don't know :tomato:
Did you checked the corner weight of your car? Just for me to have an idea of comparison with mine. I did find that the balance front to rear is not that bad, with a small block.
I bet Heartland has a set of scales in impound. Might be worth the trip one weekend for a track day. Or at least a phone call. Probably more accurate.
