69427
Z bar in 6061 sounds reasonable. A little (very little) more deflection because of the lower modulus of elasticity but strength is similar to mild steel original. Might sleeve the linkage bar bearing surfaces with a sacrificial bronze insert (like shift levers) where the link bars attach. Don't think fatigue is a concern with current low use of car. IIRC the captured stud is held in place with a wire ring clip in a groove - replicate the OE pocket and reuse the stock ball stud and seats.
We're pretty much on the same wavelength here. I had envisioned putting bushings in the linkage arms and also one in the tube where it rotates on the ball stud on the engine block. The captured stud still has me thinking, as I'm not convinced yet that I'm talented enough to be able to fabricate the groove needed for the snap ring. I still have a bit of time to figure out how to "duplicate" that while I'm looking for the tube material (my favorite local metal place didn't have what I was looking for the other day).
I agree that fatigue shouldn't be a major issue if I correctly size things (I did do a bunch of torsional strength calculations to amuse myself the other week during down times at an extended family gathering). The clutch linkage doesn't get that much day to day use, and I'm curious (as I'm not a mechanical engineer) if the fact that the bar arms (and each finite area of the arms) are only stressed in one direction (just one half of a cycle, not a complete, reversing cycle) reduces the effects of any cycling. I welcome correction or clarification from any metals experts here.
