made some progress today - Karmann Ghia
today, I almost created a parts car for you...
as a public service announcement, I'll say this:
When you see a Hummer coming in on your left side, the wrong choice is to gun it - your car doesn't have the balls to pull off that maneuver...
lol.... you could crush this thing with a Geo Metro..... with that H3 it's going to feel like a mall speed bump......
ok, made some progress on the rims, I got the inside painted, outside is next......
two coats grey epoxy:
two coats white basecoat, followed by three coats clear
ok, it's been a few weeks and here's the "progress ": i got a battery and my plan was to bleed the brakes and get the Ghia off the jackstands....
well, didn't happen...... two bleeders snapped on the front calipers so I ended up buying two calipers.... while I was at it I repaced the rotors, wheel bearings, tie rod ends.....
now I have two drop spindles on order as well as new ball joints.....
stay tuned .....
wtf? ......
al I can say is WTF...... big capital letters.......
I got new calipers from a local VW resto store, TriangleAutoparts in Winter park, tjey're AWESOME !!!!!!
too bad I decided I need new rotors (old ones had been machined) ..... so I got new tie rod ends, new rotors, new wheel bearings, new calippers, new seals..... $350 later I was on my way back home......cheaper than Vette stuff at least :lol:
pulling the front susp beam tomorrow :)))))))) .... :lol:
ok...... after a few days of pure pain I finally got the font suspension and axle beam out........
come to find out a few torsion leaves are missing so now I have two sets on order (upper and lower torsion tube) .... cut the beam to weld ride height adjusters in place, going to be adjustable +- 1" up/down ... starting 2 1/2" below stock because of the drop spindles :)
her's a few pics:
beam cut and blasted..... also blasted the disc brake backing plates and one last part of the engine tin......
here's the beam halves in epoxy primer.... you can also see the shock towers are welded solid, from the factory they're only spot welded
here's the backing plates primered.... in the background are the drop spindles......
cut the beam in halves to weld adjusters in.... that torsion spring setup is really growing on me.....
beam welded and painted.....
here's the Ghia as of tonight: 2" drop spindles installed, new shocks, new brakes, just what the doctor ordered......
got the throttle linkage sorted out..... the carb is a Weber progressive and apparently this one was not designed for a VW, the throttle turns counter clockwise which made the install a little more difficult.
installed the headlights and front bumper.....
It's alive !!!!!!!! Have to fix a oil leak at the pushrod tubes, other than that it runs great !!!!!
click image to start video !!!
If a VW engine does NOT leak at the pushrod tubes, how will you tell if it's got oil in it?
:shocking::hissyfit::pprrtt:
Since it is FLORIDA, I would have taken a sawzall to the top, making a roadster out of it, :beer:
