1958 MGA Coupe
about 90 mins tonight all the screws and nuts are "sorted out", my son spent some time today cleaning up the front of the frame
these are the next items to fabricate 6 of them looks like to me
this sets up the bent piece to have the first hole cut by the plasma cutter all at the same level
you then have to chase the hole
this makes the last indentation
now we make the clip for the fuel line and brake line all as one piece then cut with a grinder
that was kind of fun
about another hour tonight wire brushing the bottom of the frame, doing some grinding to where the spot welds were alittle bit rough and then painting the bottom of the frame with Jasco
full day today my son and I.
wire brushed the frame twice, and wiped it down with cleaner and a scotch brite pad, removed shock absorbers and bump stops and front brake lines and 4 way brake union. and then primed it.
Why didn't you have it blasted and powdercoated? A lot less messy. Does look good though. Are you going to wax coat the inside?
this area really sucks for anything car related, finding places to get stuff sand blasted is a real chore and its never close, so this build is just going to be an easy on the wallet build, and i dont mine the labor its my form of exercise. as for the rust inbitor in the frame, when i cut the rust out some of the inside of the frame was still bare metal....all of the rust was from the outside . there are several drain holes in the frame i could use to spray stuff up in there if i want to.
about 2.5 hours today painting the frame, frame extension and cleaning the front spindles again.
this gave little better pivot point then yesterdays set up
i figure the frame weighs some where in the 300-350 lb range with the steering rack and steering wheel on it. easy enough for the young bucks to pick up one end by themselves but a little heavy for dad...
this will allow us to move it out of the way easy enough so i can paint the rear end and reattach it. that is about exactly where the center of balance is for the frame.
about 2 hrs tonight removing the emergency brake cable, removing black paint from nose of the rear end, degreasing it, draining the differential, sanding it and painting it with Jasco rust converter.
easy 45min tonight, so little joe and i go to pick up the rear end assembly and it seems a little heavy to me so we put it down again....so little joe says "dad let me do it" and he wraps his 37" arms around it and picks it up and puts it out side on the jack stands....young bucks.
I'm 40 and my gym buddy is 26 ..... I think I know what you're saying...... lol
yes many of those are exactly the same parts. where is catlin?
about 3 hrs today while every body went to the pool or to play lacrossse
not a bad one person job putting the rear end back in
some welding,drilling and grinding make these usable again
priming
painting
i didnt expect a loyalty test today, i thought that was only for work. about an hour today
removing the front ww hub
oh yeah that cotter pin is fun thing to remove...i would like to meet the sick bastard that thought that one up, here i am prying it out the last 1/8"
took a few fittings to get the corrects parts for the puller set up
the orientation of the 1/4" hole towards the steering arm
and i win
well the other side is done, also what a PITA those cotter pins were
this is the new challenge
lets see what 12 tons of pressuere will do
i win!!!!!
just propane heat until the grease was bubbling out and then lots of pressure, even after the first pop of a 1/4" I had to reheat it go the rest of the way.....and if you are wondering thats a pitman arm off of a corvette and those are main caps of a SBC. I seem to have misplaced my blocks for the press
hmmm, I need a just a bit more blocking for my press - and there's a 400 in my shop that the block absolutely toast... hmmmm :suspicious:
those main caps are sweet....nicely machined with a decent span, thick as shit, and have that nice radius open end. and you could bolt them together for a large hole
