SuperBuickGuy
amazing work :thumbs:
			This is some really NICE WORK! I have a couple of quick questions:
1. How far aft do you reckon the engine is from stock? 12-13 inches maybe?
2. Who built the drive shaft? I'll need a shorty too as my engine is that far aft as well.
3. What "brand" is the steering unit? Looks like a short track unit? Speedway maybe the source?
On the steering - I like the position it is in too - well forward - I may copy as I'm having some shaft line up problems in the "stock" location. Can't see the front hubs - guess they are "reversed" to get the tie rods up front. Photos when you can - please.
Very sanitary looking chassis - really, really nice.
Looking good.
I've been trying to figure out if it might make sense to put a similar shaped/full length pan on my engine (I'm still running a wet sump). It would give a bit more clearance from the crank on the front half, and a bit more capacity, but I still haven't resolved all the slosh/trapdoor issue questions yet.
I would say if you don't need more capacity, then don't add it. It seems like you have your car dialed in pretty well... I'm surprised you don't have (need) an accusump... also, a quart of oil is a fair amount of weight!! Im thinking of running oil cooler-less in hopes that my added capacity and external oil storage away from the hot motor will stay reasonable during 20 minute track sessions. wishful thinking...
69427;130720 I have an Accusump that I've been kicking around putting in the car said:I've seen them mounted behind the gills in the fender... but that doesn't help with your Zbar issue... new lighter, relocated clutch linkage? Sounds like a good winter project to me!
Chris,
Beautiful work. The ABS unit mount looks very tidy! I don't know if you are following lateral-g, but Sutton is taking a real beating from one of his turn-key track warrior customers. They have only had the car on the track twice (at Thunder Hill), and it was quickest in TTU with only a few laps on it....but the customer is "very ill" and expected a completed, turn-key race car with no issues in 4 months build time.....not going to happen. They had a dry sump oil leak issue and some cooling problems with the 707 hp LS, which the customer did not appreciate so he started an all-out smear campaign. There may have been other personality issues (on one or both sides), but the Sutton-designed suspension was phenomenal. I don't know anybody who understands front suspension geometry better than Ron. I hope they get it worked out soon. BTW, that Sweet rack is the way to go and their customer service is great.
Pappy
I'm not on Lat-g... Was that Weld's mustang? I understand the urgency of getting some races in before he can't do it anymore but building that level of vehicle im surprised a 4 month timeline was even proposed as a possibility! i guess some people don't understand what building a 1 off race car really entails... Hell, how much money do you think GM spent on developing the c7Z? And even they messed up the cooling system when it was put on track duty. But from the discussions I've had with ron I'm fully confident that I'll have a chassis that will perform very well.
And thanks! I just hope I can get the ABS unit to work! It's low on my list of to-dos though... I imagine it will just be a heavy distribution block for a while
"I'm not on Lat-g... Was that Weld's mustang? I understand the urgency of getting some races in before he can't do it anymore but building that level of vehicle im surprised a 4 month timeline was even proposed as a possibility! i guess some people don't understand what building a 1 off race car really entails... Hell, how much money do you think GM spent on developing the c7Z? And even they messed up the cooling system when it was put on track duty. But from the discussions I've had with ron I'm fully confident that I'll have a chassis that will perform very well."
Yes, it was Weld's car. I just ordered (through Sutton) a Speedway Engineering step-up front sway bar to get the high rate I need.
Pappy
Pappy
Please pardon my ignorance here, but what's a "step-up" bar?
Pappy
Pappy
Let me know when you get yours... I ordered my clip from Ron in December, received it february-ish and was told the speedway bars were backordered... I dont need it to continue working on the car so I havent been hounding him for it but if I had a completed car and was waiting on a bar Id be a little aggravated.
Got the sway bar - came as ordered. Ron said he got several custom bars in, so I suspect you probably got yours.
Pappy
Pappy
It did come in, but as per the e-mail I got a few days ago its not looking good for Ron. A shame as I was really very happy with everything from him. Might have to see if I can privately contract him for suspension tuning/optimization once my car is more together...
Things got crowded on this side of the motor quick!
Both of the -12 lines coming through the motor mount will be getting a heat sleeve and a titanium heat shield to protect from the headers.
The pressure-out from the filter housing will go forward along the frame rail to the oil cooler, then back up the drivers side to go into the block.
May I ask what material size/dimensions you have there on your lower A-arm crossmember? I suspect my crossmember is a bit overbuilt (novice overbuild syndrome), and I am considering doing some material removal on it over the winter for some weight savings.
all I can say is I'll be treading a path that looks very similar to yours. So much so that I could be charged with plagiarism... most especially that cradle. With that said, there's only so many ways to skin a cat. Thanks for the inspiration.
