While all of you were enjoying your 4th of july BBQ's I did a little bit more to the car. I got the window in the door, added new outer window sweep, added the mirror wind deflector.
A test of the motor was successful, I cycled it about 20 times and it did not do anything but work excellent. UP times are at about 3 1/2 seconds, Down a little bit slower (maybe the tension spring on the regulator) but at any rate this window is very fast compared to the drivers door glass. I will change the drivers door motor internals as well.
The window sweeps are from willcox corvette, very very good quality and perfect fit, just align the clips & push down, then add two pop rivets and they are installed. Identical to how the factory ones are.
The mirror deflectors are GM parts and the fit was excellent! Just press them against the mirror drill a pilot hole, then install 1 rivet and tighten it while still leaving it just a tad loose to make a final adjustment. Then drill the other holes and pop riveted them down. No template needed at all, a perfect fit in all aspects. Not sure what the reproduction ones are like, I got these off ebay for 60.00 shipped.
I also re-wrapped the entire door harness. I still have to do a very minor door alignment then a window alignment & buy new clips that secure those rods in the door. I also have to replace the door handle since I broke it. Next weekend will probably put the drivers door on it.
I decide not to paint the jamb since white may not end having it white when it is repainted, leaving my options open.
