MYBAD79
Moderator
Not that you need any encouragement..... But hell, this is going to look cool
Not that you need any encouragement..... But hell, this is going to look cool![]()
Do you think that Lancia rear window glass has about the correct dimensions? A quick search showed the surrounding gasket and window louvers are still available on Ebay.....
Would be cool if you could find a Lancia rear glass incl the defroster.....
Still would be nice to have something that has some "factory" dimensions but that Lancia is probably way to rare anyways...
If you ever need a new piece of glass it would be cool to have something that is available but then again, rear glass never really breaks.....
Is that C3 hardtop a rear glass window or poly (plastic) ???
Denis,
Looking at your rear window mod, which I really like by the way, a thought came to mind. Are you going to do anything for cabin vents back there?
I don't know if your car had "AstroVent" grills behind the rear window like mine, but even if it didn't I highly recommend doing something, probably in the buttress just behind the side window, like some of the Baldwin Motion cars or the old Ford Shelby Mustangs, or the early C2. It makes a great difference in cabin comfort.
Non-A/C cars had a vacuum operated flapper I believe, probably connected to the heater controls. My car, having A/C (when it left the factory), had permanent mounted plates covering the openings. I removed the plates and made a flapper I can open & close from the seat. I leave it open year round--full open in the summer it draws noticeable airflow through the cabin with the heater control on 'vent' and the windows closed. In the winter I leave it partially open and it helps draw warm air in through the heater.
Gills in the buttress would look cool too......
John, not sure you related to the height as a advantage or a disadvantage.Denis - that is some very impressive work you are doing on the rear window mod. I am only 5' 10" and I can't imagine doing what you are doing!!!
Keep up the great work - very inspiring!!
John
While I respect the Motion design, I'm rather after the hardtop look in term of window slope.almost identical to what Joel Rosen did with the Motion corvettes back in the day. made the interior way more useful , less like an El Camino inside.
Hey, good point you got here.... made the interior way more useful , less like an El Camino inside.
