Power Windows
After hanging the repaired door shells, I decided to install the Spal power window kit now before the door skins go on.
The kit I choose basically is a motor driven cable loop that drives your original window regulator. Mount the motor where ever you can.
Regulator with motor:
Motor, inside view:
Motor, outside view:
Interior door handle and lock
Changing the interior door lock to a late model style required fabricating a mounting assembly attached to the door shell that could be adjusted in or out according to the door panel that I end up with.
That was pretty straight forward, but the original handle used a push motion to lock the door. To get this motion, I added a push/pull rod on top of the door shell and fabricated a lever assembly to operate the lock trigger.
Interior handle in place:
View inside of door shell with handle mount and push/pull rod:
Locking lever assembly:
Outside Door Handle
When I got the car, the outside door handle would open the door but there was no key and the locking function was not working.
Whilst investigating, I discovered the "barrel cup casting" on both sides had the top portion broken off.
Using 20 ga. sheet metal, I fabricated one left, one right, re-keyed the tumblers to my TR6 key I had and put it all together.
Broken barrel cup with spring exposed:
Building new barrel cup:
New part with broken barrel on right:
Assembled:
![1668865806549.png 1668865806549.png](https://data.vettemod.com/attachments/53/53148-0653b1efa7467aab8d3b2e2be930942f.jpg?hash=BlOx76dGeq)
