bobs77vet
Stainless Steel Trim
Jaguar had metal trim on the door panels and what could be called luggage runners in the boot. I received none of these when I got this car. I’ll have to make my own.
I choose 3/8” dia., 0.049 wall, 304 stainless tubing. With a zip saw, I cut it in half, then welded a trimmed 6/32 nut to the inside for mounting purposes. The upper pieces on the door panel had to be mitered to create an angle. Other pieces required a slight bend to follow the panel shape.
To split the tube, I clamped one end in a table vise and secured the other end to the table. Following the marked masking tape, the saw cut went quickly.
Cut setup:
The whole job was quite time consuming. The zip cut and welding would distort the thin wall tube and the tack would create a raised section. All that would require a file for leveling and various grades of sandpaper and buffing to gain the look of chrome. A job I wouldn’t want to do full time…
when i grow up i want to be this guy!!
