SuperBuickGuy
pictures .... my imaginator is on the fritz
That is nice and tidy. For most situations, it will probably be adequate as you say. How often would you be at a max load condition for long enough to actually drain the battery? Probably not too often. I think the packaging benefits will far outweigh the potential overload issue.
Thanks! While the battery is quite small, I agree... the power steering pump is actually supposed to connect to the charge light terminal on the alternator so it would in theory turn off until the load is lessened but I want everything except the pump to shut off in that scenario. I think too much... back to work so I can drive this thing and prove my theory wrong :flash:
Did I miss a picture or post of what battery you're planning to use? Please pardon the oversight if I missed it.
I'm using the same design alternator as you. I'm still in the process of trying to find a low cost pulley replacement (ie: larger diameter) for it. Even with my underdrive crank pulley the alternator has got to be turning some serious RPM during track days.
I was running an odyssey PC680 (15.4lbs) but I think I’m going to try their PC625 (13.2lbs). What is the pulley ratio on your alternator? Mine is 1.45:1 overdrive. I’m thinking I may need to drive it even more but at 6500RPM the alternator is already closing in on 10k rpm. I inquired about the max recommended shaft speed but I’m not holding my breath waiting for a response...
I calculated my pulley ratio to be 2.3:1, so it's turning a bit faster at times on the track than I care for or need.
A major milestone tonight! Looking through my photos, it shows I took the body off on November 30th 2014!! Thankfully I didn't hit 4 whole years :3rd:
I've got a few places to trim for 100% fitment but otherwise all went fairly smooth! My goal is to have a car that moves under its own power by New Year's Day... back to work!
Any chance your original fuel tank is available to get an empty weight?
Absolutely no rush, obviously, but thanks for any help.
22lbs with the cap and sender still installed :drink:
Rear tire showed up for mockup/wheel fitment... 345/30/19 Toyo R888R
a 2.5" flare would give me ample clearance on the frame and wheel tubs, I may run it a bit tighter to the frame once I get the wheel fit tool and see where everything ends up. For now its just thrown in with no account for camber or toe. It sure looks beefy!
