Today I set the ride height on the car. Mike walked me through the entire process. Remove the front shocks, and get yourself some heavy 1/2'' all-thread. Jack the car up onto three jackstands, not four. One under the diff, and two just behind the frame horns. Level out the back of your frame using this crossmember. Shim the two front jack stands until the frame is level side to side.
Take your all thread and cut it into two 18'' pieces. You will need to make a plate which bolts to the bottom of the lower a-arm with a hole large enough to fit the 1/2'' all-thread through. This centers the all-thread in the a-arm and also acts as a "giant washer".
Alright, here's the next step. Get out the AIM and find the page with the ride height specs. Here is one for the 76...
See the "Z" value in the top left corner of the pic? Well, that is the value you are shooting for. You want the curb height, which is the height when the car is on the street. The value for the '76 vette is 3.06 inches. You need to get two measurements to calculate this value. However, you need to ballpark the tightening of the all-thread before you take any measurements. Tighten it downuntil there is about 2'' between the lower a-arm rubber bumper and the bottom of the frame. This is a guess. Now, get yourself a level and level it on the floor, just below the lower a-arm bushing and the bottom of the front spindle.
The reason for the level is because an unlevel surface will mess around with your measurements, and that will do you no good. The first measurement you need is from the center of the lower a-arm bolt, to to top of the level.
The second measurement you need is from the bottom of the spindle, to the top of the level.
Take those two values, and subtract them from each other. For the '76, the value should be 3.06, which is about 3 & 1/16''. Make sure you do this for both sides, and get them exactly the same. You probably will not get it the first try, but just loosen or tighten the nuts until you reach the value in your assembly manual.
For the rear of the car, you will need to get rid of your spring bolts. Cut two pieces of all-thread about 4'' longer than your bolts (I think). Put them through your t-arm and then through the spring.
Drop the car back on the ground, and loosen them until the half-shafts are just "under level"
Make sure they are identical side to side. Use the crossmember (the one you put the level on before) as a reference point when adjusting each side. They should look identical. Roll the body back and forth until it settles the rear of the car. If your half-shafts are near level, and symmetrical to the crossmember, then you are good. Because I was using my old worn tires for this setup, I had to make sure they were all identical in "wear". Take measurements from the edge of the rim to the floor on every tire. Use air to raise the rim or remove air to lower the rim (this is another tip from Mike's amazing brain). Make sure all four wheels are identical. Stand back and smile with joy - you are ready to start putting sh*t together:thumbs:
Once again, a big thanks to Mike Dyer for all the help on this. He told me how to do everything. I just listened and moved my hands. This took me the entire day. This job is very tedious, but is necessary before you fit the front end and your flares.
